Moving scenery with magic
What happen te the troops inside scenery when you move it using magic? Does the unit move within the scenery? Or does it remain stationary in place and you only move the scenery? And if you move the scenery over a unit?
Thanks
If the terrain piece is moved, then the unit is moved with it.
If the terrain piece is removed, then the unit stays in place.
Thanks :grin:
So if the scenery ends over a unit, then the unit is considered to be inside it? Maybe it should pass a dangerous terrain test? :thinking:
Thanks again
Theoretically no dangerous terrain test (unless the piece of terrain was dangerous already), but if you want to do it like that it sounds fun too! :smiley:
