Post by disposable24 on Sept 27, 2021 1:34:24 GMT
So I have been printing out FTL ships from OnePageRules for about a month now. Not to many issues, just the occasional failure on the fighter units. I just switched to the Water Washable Resin and I'm having issues with getting the fighters to print. I have a Elegoo Mars Pro and I'm using the settings provided by One Page Rules for this model. Any recommendations for the Water Washable Resin? At this point I don't think I will be getting it again.
Post by federebus on Nov 4, 2021 14:48:40 GMT
I also switched to water washable, and i saw an increase in failed prints. My partial solution was to increase the exposure time from 8 seconds to 12 seconds. the supports are a bit harder to remove, but i no longer had misprint
Post by jonasfox on Nov 16, 2021 5:00:28 GMT
I run a Mars 2 Pro with the plant-based resin which I believe is in the same category as the water washable. When I calibrated my printer using UVtools the optimum print time for detail was around 2.5sec. I was getting fails on some things, more so than I would have liked. After talking to some folks I was convinced to try overexposing. I upped my exposure to 3.2 seconds and that solved almost all my print issues. That and I make sure my print space is 85f plus using a little space heater. I tried to see any loss in detail by the increase in exposure but it's almost completely negligible.
