Post by kurttheviking on Jan 18, 2022 18:40:05 GMT
With the split rule, a pink warrior can turn into 2 blue warriors when "killed". in regular GF, the split applies immediately which allows wounds to "carry over" into the newly spawned units, a point that is also discussed on discord. However, in GF:F, because a unit is not "killed" until after checking for wound effects, it seems that all wounds pile onto the pink warrior, then the pink warrior checks for effects, and only then could it be "killed" and turned into 2 blue horrors. So, in GF:F, wounds cannot carry over into the newly spawned blue warriors. Is that correct? Following the spirit of the GF rulings, I wonder if a better phrasing for the split rule on pink warriors is something like, "When a Pink Warrior receives a Wound, you may immediately split it into 2 Blue Warriors. This replacement occurs before applying additional Wounds". So in effect, the player only starts checking for Wound Effects if enough Wounds were dealt to bring the Pink down to Blue and then down to Yellow.
