Post by jarzynek on Aug 13, 2022 22:42:24 GMT
The "Pain" spell is: Target enemy model within 12'' takes 2 hits with AP(4). Most of spells/abilities refers to units. In this case, can I select hero attached to a unit as a target? Seems to be very powerful.
Post by menacing on Aug 13, 2022 22:46:40 GMT
You can do what the spell says you can do
Post by green on Sept 26, 2022 17:02:57 GMT
Why don't you name it sniper, so it is clear for all. I also had trou le with the wording.
Post by baradaeg on Sept 26, 2022 17:19:27 GMT
Because Sniper is completely different. Also what is so hard in differentiating between "model" and "unit"? As a reminder, this is from the Rulebook to clarify the difference:
Post by green on Sept 26, 2022 18:25:23 GMT
It was just my initial thoughts. So what is the sniper rule? Target a model and hit on 2+. You could easily make the spell sniper. Would be more consistent.
Post by menacing on Sept 26, 2022 19:40:51 GMT
but the effect of the spell is already clear, in plain text. you pick a model to hit with the spell. it doesnt need sniper. and it doesnt have a hit roll, so part of the sniper rules is irrelevant and is going to raise questions from why a SPELL has something mentioning a hit roll. There is no issue here.
