Post by pg8 on Jan 16, 2023 1:54:31 GMT
problem about choerency: i use ork g.w. and they have 32mm bases and when a ply orde about 20 model in a group it's almost impossible mantein 6" x 6" choerency and totally impossible when i disembark. i need some help pls.
Post by menacing on Jan 16, 2023 2:45:03 GMT
uhh that isnt difficult at all. 4x5 rows, staggered or not and you'll have plenty of room to spare
Post by pg8 on Jan 16, 2023 3:19:11 GMT
don't understand you explain: i'm italian use some example pls
Post by menacing on Jan 16, 2023 3:40:03 GMT
ooooo ooooo ooooo ooooo
Post by pg8 on Jan 17, 2023 0:32:27 GMT
when i disembark 20 models in 32 mm bases and needs to stay 1" off the transport it's impossible disembark in 6X6" and if i disembark to charge this becoming more difficulty. 20 models orks stay in battletank and that miniature is about 6" wide than it's impossible
Post by menacing on Jan 17, 2023 0:52:04 GMT
It is falsifiably not impossible. I don't know what you're doing with your models but you are not doing it correctly. It is not difficult to do.
Post by barrys on Jan 17, 2023 7:15:33 GMT
Hello, pg8
I asked this question a couple of years ago and the reply was that you should simply try your best to keep coherency. The rule was there to prevent players arranging their unit into bizarre lines or formations to gain an advantage.
I'm not sure if my original post survived the various reboots of this forum.
B
Post by leadjunky on Jan 21, 2023 5:55:11 GMT
We simply just expand to 12" for 20 model units. No one seems to abuse this in our group so we've not had any issues.
Post by ariktaranis on Jan 21, 2023 18:28:54 GMT
Just keep it as close to the proscribed distance as possible. It does t have to be perfect, the rule is just to stop bullshit like conga lines ruining the fun I think.
egge
Member
Post by egge on Jan 30, 2023 14:35:27 GMT
problem about choerency: i use ork g.w. and they have 32mm bases and when a ply orde about 20 model in a group it's almost impossible mantein 6" x 6" choerency and totally impossible when i disembark. i need some help pls. A paint picture included to show how you can do. Hope it helps. For 6" coherency it is enough that a tiny part of the base is within 6". Just like the 2" coherency. And I'm stupid... got the measures on the wrong side in the picture. Point is, all bases does not need to be wholly within 6" of another. Just the tip of the base. So 99" of the base can be outside of 6". Attachments:
